Ensign-Bickford Aerospace & Defense Company (EBAD) is a leader in energetic system solutions offered to aerospace and defense customers for a wide array of applications. EBAD products & capabilities set the U.S. standard and are highly sought after in the international community.
There is an open position for a CNC Programmer with Ensign-Bickford Aerospace & Defense Company in Moorpark.
The CNC Programmer is responsible for designing fixtures and programming precision-machined parts. The position would be responsible for multiple CNC machines including 8 and 11 axis Swiss machines, Dual spindle lathes with live tooling, and 5 axis and 3-1/2 axis Mills. Parts are smaller in size, 12” max. Most runs are short, 10 to 200 pieces.
Principal Duties and Responsibilities:
· Complete fixture design using SolidWorks software.
· Complete part programs using Esprit software.
· Identifying tools needed with complete tool list and setup sheet.
· Working at the machine with machinists to run first piece and debug issues.
· Using proper methodology and cutting tools to produce quality parts that adhere to production and quality standards.
· Using proper feed, speed, and other cutting parameters based on work piece matls such as aluminum, steel, stainless steel, titanium and Torlon.
· Revising programs as needed based on engineering or production required changes.
Ensign-Bickford Aerospace & Defense Company is an EO Employer-M/F/Veteran/ Disability. All qualified applicants will receive consideration for employment without regard to race, color, religion, sex, national origin, disability, protected veteran status, sexual orientation, gender identity, or any other protected class.
