Don't you think it might be useful to indicate which country you are based in?It does help if the programmer is in roughly the same time zone......
Ideally a person within a reasonable distance for a one time meeting would be best, but we are willing to look at all freelance programmers and their business models from all over. Mastercam but if you use a different software and it ends up coming out the same as our desired results, thats totally fine.
This is for programming 4 axis Makinos...to be honest, to the right person, I bet this programming would be pretty easy, however, due to the lack of memory in our machines, we currently use very few lines with sub routines grabbing them from the server...
We would still need to keep things this way.
The type of part to be programmed, will always be the same, just different variables...
I may not check back here for messages always, so feel free to email me
metrologysolutions@gmail.com
Jim
Yes, so sorry...Windsor, Ontario. EST
hello i am chinese
Nihao (hello) I have been engaged in CNC programming for ten years in China. I am proficient in MASTERCAM
The software used in the work is POWERMILL nx hypermill vecut, which can make a perfect cutting path. The same four axes and five axes can be applied remotely if necessary
Mailbox lwb376139639520@gmail.com
thank you
