Cnc foam cutting machine designer, builder, programmer, operator needed in MI, USA
Results 1 to 6 of 6
Thread: Cnc foam cutting machine designer, builder, programmer, operator needed in MI, USA
    Member Reallypistauf's Avatar
    Aug 2016
    Default Cnc foam cutting machine designer, builder, programmer, operator needed in MI, USA
    Job opportunity in Central Michigan for someone that can design, build, program, and operate a polyurethane foam cutting machine and other machines using similar technology. Unlimited growth potential.
    Aug 2016
    Default Re: Cnc foam cutting machine designer, builder, programmer, operator needed in MI, US
    Still am looking
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi RPO - I think you need to provide more info about the situation eg what size machine, what size parts and production volume. Is a 4-5-6 axis machine needed? etc the more info the better
    If the opportunity is real then buying a commercial machine(s) makes more sense (and will be more economical medium to long term) then designing and building one depending on the situation. Peter
    Aug 2016
    See some of my other postings. Fairly simple design - only 2 axis, size approx 4' x 6' footprint. Will do the work of commercial machines costing $100k and can be built for likely under $5k (parts and labor).
    Wonder why it says I'm posting via mobile device; I post using a desktop - ???
    Aug 2016
    Still looking - also someone good with online operations, computer tech, internet, marketing, website design, etc. - unlimited growth opportunity
    Aug 2016
    We actually can produce machines to sell ($$) as well as for our own use.
