CNC MACHINIST OPPORTUNITY IN NORTHEAST GA
Results 1 to 2 of 2
Thread: CNC MACHINIST OPPORTUNITY IN NORTHEAST GA
    Equiles's Avatar
    Dec 2019
    Default CNC MACHINIST OPPORTUNITY IN NORTHEAST GA
    Benchmark designs and manufactures high-performance, low-maintenance, easy-to-operate product handling systems for food and bakery manufacturers, including distribution systems, automatic cartoner infeeds, shuttle and disk feeders, stackers, mergers, tray loaders, and slug loaders. Benchmark also manufactures the Southern Packaging line of intermittent motion horizontal form fill seal pouch packaging systems. Benchmark is a product brand of ProMach, a global leader in packaging line solutions. As part of the ProMach Product Handling business line, Benchmark helps our packaging customers protect and grow the reputation and trust of their consumers. ProMach is a family of best-in-class packaging solution brands serving manufacturers of all sizes and geographies in the food, beverage, pharmaceutical, personal care, and household and industrial goods industries. ProMach brands operate across the entire packaging spectrum: filling and capping, flexibles, pharma, product handling, labeling and coding, and end of line. ProMach is headquartered near Cincinnati, Ohio, with manufacturing facilities and offices throughout North America, Europe, South America, and Asia. For more information about ProMach, visit ProMach - Performance, Packaged - Pro Mach Built and for more information on ProMach Careers, visit ProMach - Performance, Packaged - Pro Mach Built
    JOB DESCRIPTION:
    We are currently seeking a CNC Machinist for our Statham, GA facility. This position requires familiarity with CNC set up, programming and running machines using Hurco conversational programming, G codes and canned cycles to produce high quality machined parts for custom designed packaging machines. This is a first shift position that reports to the machine shop supervisor. Job responsibilities include the following:
    • Read and interpret engineering prints, manufacturing manuals and both verbal and written instructions to program and plan machine set up, correct adjustments, and selection of tools. This includes spindle speeds, tool feed rates, work holding methods, and all operational sequencing.
    • Produce high quality machined parts.
    • Design and make the necessary fixtures and keys to secure materials (work holding methods) for machining. Position and secure parts on surface plate or worktable using fixtures, keys, changing “chuck jaw”, vices, V-blocks and angle plates, hand tools, etc.
    • Insure all machine set ups and shut downs are in line with prescribed safety procedures. This includes all necessary Lockout/Tag out procedures when needed.
    • Strictly follow all job safety requirements/procedures which include machine guarding, forklift truck and hoist operation and housekeeping requirements. Maintain a clean and safe work environment
    • Identify and choose the proper material from raw material inventory for each job order. May be required to cut raw material from larger piece of necessary raw material.
    • Inspects and verifies conformance of parts at the beginning of an operation and the end of machining process to specifications/tolerances using a variety of precision measuring and gauging instruments.
    • Debur all necessary parts after machining operation to meet required specifications and tolerances.
    • Act as a technical resource for other employees or other plant departments to address and resolve inquiries.
    • Local travel, overtime and weekend work is sometimes required.
    JOB REQUIREMENTS:
    • High School Diploma or equivalent
    • Minimum 2 years of experience or completion of a 1 or 2-year Tool Technology or related program.
    • Familiarity with CNC set up, programming and running VMC machines, scales, calipers, micrometers and other tools used to check parts against drawings.
    • Familiarity with manual machining operations including mills, lathes and saws.
    • Ability to read and interpret detailed blueprint drawings.
    • Ability to read and interpret documents such as safety rules, operating and maintenance instructions and procedure manuals.
    • Ability to stay organized and ensure that the work area is clean, safe and orderly.
    • Ability to follow oral and written instructions and well as be punctual and dependable.
    • Ability to work overtime when needed.
    • Must have a valid driver’s license to occasionally pick up and deliver parts.
    • Good interpersonal skills and ability to multi-task.
    • Ability to perform basic math including working with and converting between fractions, and decimals.
    • Ability to do the essential functions of the job which includes a full range of physical motion including bending, stooping, reaching and lifting up to 50 lbs.
    BENEFITS:
    Salary is only a part of a well-developed compensation program. As a Pro Mach employee, you receive more than just a paycheck. Total compensation includes your pay (base salary), very comprehensive medical/dental programs as well as life insurance, a generous paid time off program, a retirement savings plan with a company match and a wellness program. There is no waiting period for benefits – you are eligible on your first day of employment.
    Pro Mach is an Equal Opportunity Employer. Pro Mach utilizes E-Verify to validate employment eligibility of new hires to work in the United States. Pro Mach is a drug-free workplace.
    Member machinehop5's Avatar
    Aug 2009
    Default Re: CNC MACHINIST OPPORTUNITY IN NORTHEAST GA
    Blueprints for Quote? or you need someone on site to help?
    DJ
    Equiles's Avatar
    Dec 2019
    Looking for a fulltime onsite machinist.
