- Build Thread- Emco F1P rebuild
Emco F1P rebuild
Hello everyone.
Did buy a emco F1P in bad shape..
Going to do a rebuild whit new closed loop motors and acorn.I will post pictures of my rebuild
All the motor mounts was missing so i had a friend water cut new motor mounts in 3mm Stainless steel for me.
One of the 80 tooth mxl pulleys was missing so 3 new pulles was machined out of pulley stock.Did change from 80 to 40 tooth on all axis.Hope it´s going to work.
That´s what i have done so far in the rebuild.
- You may not post replies
- You may not edit your posts
Forum Rules
