Emco F3 mill conversion - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
Thread: Emco F3 mill conversion
  1. #41
    Mar 2012
    New Zealand
    Default Re: Emco F3 mill conversion
    Can a Bosch bi metal holesaw cut through cast iron or do I need a carbide tipped holesaw ?
    Having fun with my Emco F3 and Super 11 CD
  2. #42
    Dec 2013
    Quote Originally Posted by fastbike View Post
    The bi metal holesaw should be fine unless you hit a very hard spot in the casting. If it is a quality casting, then I would expect no problem.
    Jim Dawson
    Sandy, Oregon, USA
  3. #43
    Mar 2012
    New Zealand
    Quote Originally Posted by Jim Dawson View Post
    Thanks Jim, I'll probably be giving this a go in the next week or so. I thought I should ask the question in case I had to order in a carbide holesaw, so nice to know I can try with an ordinary bi metal.
    Fingers crossed that Emco castings are quality.
    David
  4. #44
    Mar 2012
    New Zealand
    I'll need to make a guide piece so I can centre the pilot drill in the existing hole in the casting. That's been put on hold while I get the control enclosure/wiring progressed.
