Emco PC Turn 55 backlash Z axis
Results 1 to 6 of 6
Thread: Emco PC Turn 55 backlash Z axis
    Member hugoturn's Avatar
    Aug 2019
    Default Emco PC Turn 55 backlash Z axis
    Hello everyone !
    I am doing a retrofit of an Emco PC Turn 55 and I see that in the Z axis it has a backlash of 0.02mm (In the X axis there is no backlash)
    Attached photo of the Z axis ball nut support.
    Does anyone know how to adjust the preload on this ball nut? There are three screws, two hex head and one slot.
    Hugo Gonzalez
    Aug 2019
    Default Re: Emco PC Turn 55 backlash Z axis
    Some photographs
    Attached Thumbnails Attached Thumbnails Emco PC Turn 55 backlash Z axis-img_5011-jpg   Emco PC Turn 55 backlash Z axis-img_4984-jpg   Emco PC Turn 55 backlash Z axis-img_5010-jpg   Emco PC Turn 55 backlash Z axis-img_5009-jpg
    Emco PC Turn 55 backlash Z axis-img_5012-jpg   Emco PC Turn 55 backlash Z axis-img_5010-jpg
    Aug 2019
    Hello !
    Could someone send me a photo of the Z axis ballnut because I have doubts that the one I have is the original?
    That photo may be of the "PC Turn 50 or 55" or "Concept Turn 55"
    Thank you
    Hugo Gonzalez
    Dec 2013
    If it is not a double nut, then the only way to preload it is to install larger balls. Not an easy task. I can't see enough of the nut in the picture to say what it is.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2019
    The ballnut that I have installed on the PC Turn 55
    Is it the original or has it been changed?
    Attached Thumbnails Attached Thumbnails Emco PC Turn 55 backlash Z axis-img_5028-jpeg
    Dec 2013
    Sorry, I don't know
    Jim Dawson
    Sandy, Oregon, USA
