- Emco 220 parameter issue
have an Emco220 w/TM02 control and for whatever reason we lost all of our parameters. I have the sheet provided to me by EMCO with all of the Parameters (letters F, D, etc and parameters 00, 05, 10, etc) Now, I know how to get to the settings with MONITOR, and I can SEE the parameters they are talking about (meaning, I can GET to f40, d05, etc). However, on that sheet across the top there is a 0, 1, 2, 3 and 4. There are five, sometimes different, numbers for each parameter. How do I know which one I choose? How do I know if I choose the f40 parameter that is under the 0 column, or under the 4 column?
Any help would be GREATLY appreciated
Re: Emco 220 parameter issue
Hello,
Any progress restoring the parameters?
Anyone who can explain how to download the parameters from EMCO to PC (via RS232) ?
Given that the RS232 connection is working, what is the procedure to download the machine parameters for backup purpose?
And what whould be the procedure to upload the machine parameters to the EMCO again in case that's needed?
Thanks in advance
- You may not post replies
- You may not edit your posts
Forum Rules
