- Problem- Emco 220 parameter question
have an Emco220 w/TM02 control and for whatever reason we lost all of our parameters. I have the sheet provided to me by EMCO with all of the Parameters (letters F, D, etc and parameters 00, 05, 10, etc) Now, I know how to get to the settings with MONITOR, and I can SEE the parameters they are talking about (meaning, I can GET to f40, d05, etc). However, on that sheet across the top there is a 0, 1, 2, 3 and 4. There are five, sometimes different, numbers for each parameter. How do I know which one I choose? How do I know if I choose the f40 parameter that is under the 0 column, or under the 4 column?
Any help would be GREATLY appreciated
- You may not post replies
- You may not edit your posts
Forum Rules
