- Problem- EMCO Concep Turn 450, no connection to ACC
Re: EMCO Concep Turn 450, no connection to ACC
Ok- we have tried to start our SIEMENS 840D from control panel with removed ACC PCI card- program start up, show an error 8257 Real time module not active or PCI card not found! (of course- because it is removed) and shuts down. When PCI card is placed in ACC module and all cables are connected, in case of starting a control program, PC tries to communicate with ACC and in the middle it stops. Nothing happens there. Any ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
