- Can't Reference EMCO 360 Turn
I re-commissioned my EMCO 360 Turn because of a battery failure. Machine was running fine before the memory was lost, after re-commissioning when trying to REFPOINT by pressing X+ the axis does not move unless the Aux On is held at the same time, then the axis will move to the reference point. This is the same with the Z+ axis. I have seen in other posts that guys were having problems with the PCP not fully loading. I think my PCP is fully loading, but I'm not sure how to tell. Any help would be greatly appreciated.
Re: Can't Reference EMCO 360 Turn
Update, I got the machine to Reference +X and +Z normally and everything works as it is suppose to except the Hydraulic Chuck. I can change the 5008 Bit to inside or outside and it doesn't have any effect, so I think I'm still missing something that controls the hydraulic chuck. Any help would be appreciated.
Dear sir
Hi
Is your machine EMCO 360 with GA3?
If yes, is it possible to send me its backup?
There is a same machine but all parameters and plc are lost due to battery low.
Thanks and regards
Mehdi
m.fazelfard@gmail.com
- You may not post replies
- You may not edit your posts
Forum Rules
