LinuxCNC G96 SCC problem
Results 1 to 1 of 1
Thread: LinuxCNC G96 SCC problem
    May 2016
    Slovenia
    Default LinuxCNC G96 SCC problem
    My 220P is converted to run on LinuxCNC, and at the moment I am using puller to get the stock material out.
    I tried using G96 and CSS for getting optimum finish and good cutting/parting, but after using it, I have a problem with a puller. Although I run the G94 and G97, the puller gets to the last point of G0 command, and wont do a G1.
    Is there something wrong with the code, or is there something in the setup that I should change?
    Stefan
    Attached Files Attached Files
