Emco 320 config file / sheet
Results 1 to 3 of 3
Thread: Emco 320 config file / sheet
    Oct 2011
    Default Emco 320 config file / sheet
    Here's the config file and sheet for my Emcoturn 320 with Fanuc O-TC controls, My machine is configured with a LNS Hydrobar bar feeder so you will have to figure out how to remove that part if you don't have one.
    You will have to delete the .txt off the config file.
    Hope this helps someone
    Attached Files Attached Files
    Oct 2013
    Default Re: Emco 320 config file / sheet
    Thank You!
    Oct 2011
    Quote Originally Posted by DT714 View Post
    Thank You!
    Did you ever get your Emco running?
