Manual chuck on Emco Compact 6P / 120P / 220P
Results 1 to 2 of 2
Thread: Manual chuck on Emco Compact 6P / 120P / 220P
    Apr 2008
    England
    Default Manual chuck on Emco Compact 6P / 120P / 220P
    Hello all,
    Specifically regarding the Compact 6P, although the answer's probably the same for the 120P / 220P - Can the pneumatics for the chuck / collet be easily removed so that a manual chuck can be fitted, allowing use of the through-spindle bore ? (Without removal / replacement of the whole headstock and spindle with the standard non-P unit.)
    Thanks.
    Apr 2008
    England
    Default Re: Manual chuck on Emco Compact 6P / 120P / 220P
    The similar threads have pointed me to this which pretty much answers my question, it looks like the pneumatics have just been unbolted from the spindle:
    https://www.cnczone.com/forums/showt...%20CNC%20lathe
