Need Help! Emco PC turn 55 burned inverter is the 8200 compatible?
Results 1 to 4 of 4
Thread: Emco PC turn 55 burned inverter is the 8200 compatible?
    Aug 2010
    Default Emco PC turn 55 burned inverter is the 8200 compatible?
    Hello, I recently acquired a PC turn 55 lathe. While plugging it in at home I heard a loud pop. Looked inside the machine and the inverter had some burn. Uninstalled and took apart to find a non labeled discrete resistor burned out. I found a similar replacement but I do not know if it is compatible. The model number of the one I found is e82ev751_2b200. The picture is of my original
    Attached Thumbnails Attached Thumbnails Emco PC turn 55 burned inverter is the 8200 compatible?-20181210_234643-jpg
    Registered Jim Dawson's Avatar
    Dec 2013
    Default Re: Emco PC turn 55 burned inverter is the 8200 compatible?
    I think the .2B200 means 200 volt class. I say yes, it looks to be compatible.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2010
    Quote Originally Posted by Jim Dawson View Post
    Thanks Jim. I'm going to go ahead with the purchase. They dont accept returns so if it is not compatible I will try to sell it.
    If anyone else wants to chime in its appreciated.
    Aug 2010
    Found a matching model number that was affordable. I installed and will try to power up for functionality.
    Attached Thumbnails Attached Thumbnails Emco PC turn 55 burned inverter is the 8200 compatible?-20190209_001210-jpg
