Lots of relevant info here:
See attached PDF of all software screenshots, shows all config possibilities.
Of particular interest if you only want to convert your machine to LINUXCNC using a MESA board is the AWL file. It tells you all of the pinouts. The software screenshots tell you all of the standard parameters like acceleration and max speeds.
I do a software walkthrough here:
I have a GITHUB started for converting these to linuxcnc here: https://github.com/MichaelWoodc/LINU...O_using_awlsim
Most all of the files attached here are very useful information and there's many more files with useful information I'll attach as a zip file in a later post.
