- Just bought an EMCO PC 50 milling machine. Need advice, tool holders, etc.
Questions:
- Is the stock taper iso/bt30?
- I understand it uses a special pull stud, anybody know if I can buy this separate?
- I have some awesome 3nm servos I am ready to use to retrofit, touch screen monitors, linux cnc experience, is there anything I should know?
- I was planning on using a hitachi VFD as I found in another post here. Still the best option, or should I just go with a 220 VFD since I have that voltage available?
- Any upgrades I should plan? How easy is it to put an ATC on this machine?
- Does anybody have a manual?
I'm super excited to get this, it's coming on Tuesday
- You may not post replies
- You may not edit your posts
Forum Rules
