- Emco Compact 5 CNC tool changer
Hi folks. I've just picked up a Compact 5 CNC that runs Mach 3 from a tethered laptop. Has anyone gotten the tool turret to work using this configuration? I was told "you can write a macro", but that is not my forte.
Thanks!
Chris
Re: Emco Compact 5 CNC tool changer
Hi Chris, any luck getting the turret to work?
Kevin
Do you find macro..?
- - - Updated - - -
Any update for same..?
- You may not post replies
- You may not edit your posts
Forum Rules
