- Alarm 6010: DRIVE X-AXIS NOT READY
Good morning to everybody!
I have a EMCO PC MILL 155, with FANUC 21mb Control, so, at the start of the control, for the reference of the axes, on the monitor I get the following message:
Alarm 6011: DRIVE Y-AXIS NOT READY -->(this message doesn't always come out)
I have looked at the manual and for these alarms it says--> step motor board defective. Check fuses and switch box fan filter. Low Voltage.
Someone has had the same problem, I would be very grateful for your help.
Re: Alarm 6010: DRIVE X-AXIS NOT READY
Look at page 35 of the electrical documentation for LEDs on the drive. LED1 indicates if the drive is ready. Others indicate faults. If there is no LED, troubleshooting begins by checking the fuse in the drive, and input voltage. If drives are getting good power(~130VDC), the drives are bad.If drives are bad, inspect the motor and wiring prior to installing a new drive. If voltage is bad, the circuit must be tested starting at the transformer, rectifier, capacitor, circuit breaker, wiring.
Hello,
I found the problem....it was that the control driver, was dirty with oil and grease. I cleaned it and the error disappeared.
Thanks for your comments.
I found the problem .... it was that the control driver was dirty with oil and grease, I cleaned it and the error disappeared.thanks for your comments.
- You may not post replies
- You may not edit your posts
Forum Rules
