Emco VMC 100 with Emcotronic TM02 controller (start problems).
Results 1 to 1 of 1
Thread: Emco VMC 100 with Emcotronic TM02 controller (start problems).
    Araya's Avatar
    Dec 2018
    Default Emco VMC 100 with Emcotronic TM02 controller (start problems).
    Hello All,
    I bought myself a Emco VMC 100 with Emcotronic TM02 controller.
    According to the seller, the machine stood still for over a year.
    Now i was trying to start the machine and encountered some problems.
    On start:
    pressing the "Aux on" button does notting.
    The control is in Edit mode with following errors:
    alarm 130: value out of range / invalid input data.
    alarm 460: reference position active.
    after pressing the reset button:
    alarm 460 stays on the screen.
    When i press the manual button the following errors appear.
    alarm 780: safety lock active.
    I did some research and there is the possibility that the MSD data is lost and i don't have a tape to read these back in.
    Any help and sugestions are welcome.
    Thanx in Advance.
    Araya
    Mar 2016
    Poland
    Default Re: Emco VMC 100 with Emcotronic TM02 controller (start problems).
    Take look inside of the machine. The data shuold be writen on the back cover of the control panel (the one with fans and air filter).
    The problem may be with the buttons. They are simple bridge switch and probably they won't work properly for first few tries.
