clearpath F1
Results 1 to 4 of 4
Thread: clearpath F1
    May 2015
    Default clearpath F1
    i bought one servo to try out on the x axis. more info to follow
    Attached Thumbnails Attached Thumbnails clearpath F1-20180924_141352-jpg   clearpath F1-20180924_141305-jpg
    Nov 2005
    us
    Default Re: clearpath F1
    Quote Originally Posted by chris24g View Post
    Following
    May 2015
    setup of the servo itself is straightforward, but a new experience cnc wise. would definitely advise running and setting up the servo fully on the bench before installing. since this is not really a stepper, you can put it in modes where it runs away (you can't stop it). no major incidents but that was an eye opener. the next hurdle is to figure out how to install the pinion, as there is no set screw. solutions are:
    1) drill the shaft for a pin
    2) loctite the piinion
    3) source a new pinion with a set screw and grind a flat spot on the clearpath
    anyone know the pinion specs? looks to be 16 tooth
    Member Bubba's Avatar
    Mar 2004
    lagrange
    Chris24g
    When I got my first clearpath, reading the specs, the manufacturer recommends against setscrews and keyways on my NEMA 23 series servos. They advise a couple of different friction fit pulleys instead.
    Art
clearpath F1
clearpath F1
