- emco concept 55 mill startup trouble
Hello all. i just got a emco concept mill 55. made in 2006. I have loaded the winnc on to the flash drive and plugged into the machine. All cords are connected to the right place. The monitor goes through the linux code. The monitor reads: finished update. then it asks for a username and password? Where do I get this? And I tried talking to the emco people but they are not responding.
Re: emco concept 55 mill startup trouble
if you are still around! What linux code? - The clue is in the sofware name - 'winnc'...
cheers,
john
True. You dont use the Linux machine. You connect is to a windows machine with wincam/camconcept and that does the machine control. You just found the calculation unit of the machine. In the concept mill this is different from the machine control.
- You may not post replies
- You may not edit your posts
Forum Rules
