Power off the machine.
Press and hold the “Function” key (or sometimes a key labeled “Prog” or “Set”).
While holding the key, power on the machine.
Keep holding the button until you see the language selection screen.
Hi I bought a brother hs-70a wire edm machine.
The controller is in Germans. I have the manual and there is no parameter for language. I believe you have to keep pressing a button and boot up the system for language change.
If someone knows anything please let me know.
Any help would be appreciated.
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
