Need Help! Sodick A320D AWT with EX21 control cabinet
Results 1 to 2 of 2
Thread: Sodick A320D AWT with EX21 control cabinet
    Member MelGee's Avatar
    Mar 2024
    Default Sodick A320D AWT with EX21 control cabinet
    Hello everyone,
    Recently I was able to pickup a Sodick A320D. The machine was working when the former company removed it to upgrade to a new machine. Unfortunately they cut the wires running from the cabinet to the EMD table. The wires are labeled in the panel but the labels are worn off at the terminal block bolted to both front and side blocks.
    I’m hoping that someone can help me out with which wires go where. Wires are labeled NR1L, NR1U, NR2L, NR2U, MAIN L, and MAIN U. I have purchased the new wires and need to know where they go on the table.
    Thanks a ton for the support,
    MelGee
    Member kevh's Avatar
    Nov 2004
    England
    Default Re: Sodick A320D AWT with EX21 control cabinet
    Hi
    Just wondering if you are in the UK as i scrapped same machine in Oct last year ...
    Cheers Kev
