Spindle Motor Specifications :
Power : 5.5KW
Voltage : 220V
Current : no load 7A max 15A
Frequency : RATE 400Hz max 600hz
Speed : 18000rpm max
Cooling Type : Water-cooled
Joint of nose : BT30 Taper
Lubrication : Grease
weigth: 26kg
Diameter: 125mm
Lengt: 460mm
Air pressure: 6kg/cm2
4 Bearing, 7008x2 7006x2, all ceramic p4 china brand
Packing list
1pcs spindle ATC BT30 5.5kw
1pcs power socket
1pcs airtac 5 way vale 24VDC
1pcs airtac air regulator with filter
1pcs BEST FC300 single phase 220V 5.5kw
6pcs NBT30 ER25 holder
12pcs collect ER25 variable size (mm/inch option)
1pcs UM25 , ER25 open tool
1pcs button
6pcs Holder clamp
Ship from HCMC, Vietnam
1.Orders will be shipped out within 3-5 working days once payment received. Please make sure the phone number is valid.
2.We Will ship by DHL/FEDEX/TNT/EMS serice . You will be updated the tracking number via ebay and email. Generally, it takes 12-25 delivery days to your shipping address.
3.Kindly please note the tax fee and clearance fee are not included in the item price. You have to take the responsibility for the tax and clearance fee.
4. Please contact us if you have any question
acing milling
https://www.ebay.com/itm/184341861159
thanks and best regards
- Combo spindle atc BT30 5.5kw rate 220V 400hz max 600hz 18000rpm + 5.5kw VFD sunfar
- Spindle atc bt30 3kw 5.5kw 4 pole 220V rate 400hz max 600hz 18000rpm
- Spindle atc bt30 5.5kw, 4 pole rate 220V 400hz, max 600hz 18000rpm .
- sale spindle atc bt30 2 pole 380V 300hz 18000rpm brand new
- Low cost spindle ATC BT30 3kw 4 pole 220V 400hz max 600hz 18000rpm
