- 4x8' Joe's CNC Hybrid R&P CNC Routers - Lexington, Kentucky
*Registered User*
For sale on eBay: https://www.ebay.com/itm/CNC-Router-...d/264739121388
CNC Router - 4'x8' Joe's 4x4 Hybrid.
Learn more about the design at: https://www.joescnc.com/the-machines/4x4-hybrid
4' x 8' bed handles full sheets of plywood with ease. 10' rails allow the option of adding a 4th axis at one end for rotary work. (we never added one, but it's ready for it) Bed has t-track and replaceable spoilboards. Three layers of MDF mounted on a steel subframe.
Geared stepper motors and rack-and-pinion linear control for X and Y axis. Leadscrew for the Z-axis. 4" of Z-axis travel. Machine can move over 300 in/minute, but we run it much more conservatively than that.
48V, 12.5A stepper power supply + 12V, 5A accessory power supply + 24V LED power supply.
Stepper motors are 450 in-lbs. (I think...might be 400?)
Frame is welded 2"x2" steel tube. Incredibly robust! Two storage shelves below with capacity of dozens of sheets of plywood. It fits through a garage door, or the bed can be unbolted from the frame and each fit through a standard 34" door.
PC has a licensed copy of Mach 3 installed.
Dust collection port on head.
LED strip lights.
Comes with enough collets and bits to get you started cutting. (Not all accessories in photo are included.)
We've had some issues in the past with the z-axis stepper not responding and lost steps. We recently replaced the PC, two steppers and had the Gecko G540 controller factory refurbished, and we have not seen the problem return. The wires to the steppers are about 6 years old, and may need replacing soon -- under $100 from CNCRouterParts website.
The components and materials used in this machine totaled $3,485. It was built over a few months of weekends by members of Collexion Hackerspace, and was later moved to Kre8Now Makerspace. This is a great machine that has served our makers well over the last four years. It could use a little TLC to tighten things up, but it is is ready to cut today.
The builder community for this design is strong, with hundreds of builders around the world, supporting each other and exchanging upgrade ideas. There is a GREAT forum at the Joe's 4x4 CNC website. The design is extremely open to upgrades to meet different needs...or use it just as is. Ours stayed loyal to the plans, other than the extended length and welded steel base.
More details and cutting demo here on YouTube: https://www.youtube.com/watch?v=Pn-sqs7vkIQ
Sold as-is. Pickup only in Lexington, KY, with free local delivery assistance.
Auction ends Monday, June 1. Bid today: https://www.ebay.com/itm/CNC-Router-...d/264739121388
- You may not post replies
- You may not edit your posts
Forum Rules
