Wire Flattener - Otto2 Wire Flattener
Results 1 to 2 of 2
Thread: Wire Flattener - Otto2 Wire Flattener
    Aug 2011
    Default Wire Flattener - Otto2 Wire Flattener
    The Otto2 Wire Flattener is capable of 2 way flattening of both aluminum & copper, film coated magnet wire. Flattener is designed to work with coil winding machinery. These are new, unused machines.
    https://www.ebay.com/itm/Wire-Flatte...oAAOSwH8Vd8Tr3
    Features:
    -2-way flattening of CU and AL up to 8 AWG. 6 AWG possible with larger motor and drive.
    -Single flattening head on single machine base.
    -Maximum flattening speed of 1500 ft/min.
    -Fixed rolls. No grooved rolls to purchase or change.
    -Wire thickness continuously adjustable in 0.5 mil steps from .005” to .375”.
    -6" diameter flattener rolls with digital roll gap indicator
    -Standard 10 HP motor and drive
    -Wire-out switch for customer connection to winding machine.
    -Flattener speed exceeded relay for connection to winding machine.
    -Customer connection for drive enable/disable. Typically used for low air pressure.
    -Adjustable dancer pressure.
    -Dual jog switches for manually feeding wire.
    -Quick flattener head disassembly for easy maintenance.
    -Dimension: 24" x 70" x 72"h
    Machine(s) can ship via freight at buyers expense within the United States only or pick up in Athens, GA
    Wire Flattener - Otto2 Wire Flattener-otto2wireflattener-jpg
    Aug 2011
    Default Re: Wire Flattener - Otto2 Wire Flattener
    If you are interested or have specific questions, please email us at info@douglasmachinesinc.com
