My collection of bearings is getting out of control! Come take a look. There are many more than listed below.
You can contact me directly at sales@rbpsystems.com for a package deal on multiple items or to discuss what i have that would work for your project or you can buy directly through ebay below. Im always getting new things so check back often.
Linear Stages
Square Rails And Bearing Combos
$$ Item Description Available 189 THK HRW50 Slide with LINEAR RAIL GUIDE 500mm long 4 199 450MM Rail With Two IKO MX 35 Roller Bearings MX 35 C2 R450 T2PS2/FHP 2 149 THK HRW21 580mm Linear Guide Rail With Wide Block Bearing 1 149 THK SR25W LINEAR BEARING WITH 460MM SQUARE RAIL 1
Square Linear Guide BearingsRound Rails
$$ Item Description Available 59 INA Bearing Blocks For 0.75 Inch Linear Shaft Model KTX0 12 PP 10 99 640mm Igus Linear Profile Guide and 4 Bearings (ws-10-40 640mm and 4 x wjum-01 b 8 24.99 PBC 2" Diameter Linear Bearing FL32S , Rod, Solid Liner, 4
