Spindle atc bt30 3kw 5.5kw 4 pole 220V rate 400hz max 600hz 18000rpm
Results 1 to 2 of 2
Thread: Spindle atc bt30 3kw 5.5kw 4 pole 220V rate 400hz max 600hz 18000rpm
    Mar 2005
    ASIAN
    Default Re: Spindle atc bt30 3kw 5.5kw 4 pole 220V rate 400hz max 600hz 18000rpm
    5.5kw facing mill aluminium , D60
