- Fadal VMC 4020HT 2 Kurt 6" Double Vises 60 Cat 40 Tool Holders and Tooling AZ $8500
Auction Link - http://ebay.us/yRzyrF?cmpnId=5338273189
1989 Fadal 4020HT VMC Vertical Milling Center Model 906-1 - 3 Axis CNC Machine Built During the Glory Days of Fadal CNC!
under power on site, works great!
No Reserve, Contact us for freight pricing and Info
Phone or Text Nate (602) 899-5986 Email - Admin@Beatenzonemfg.com
Includes:
1 - 1989 Fadal VMC 4020HT
2 - 6" Kurt Double Vices
60 - Cat 40 Tool holders (including various specialty tooling
- Insert Mills, End mills, Drill bits, Taps, Shell Mill, Reamers, etc.
- Toe Clamps, Step Blocks, Dial Indicator, Hydrometer
Everything necessary to make chips!!
See pictures included, additional pictures and video also available!!
Over 20k in value
Description
15HP - 10,000 RPM Baldor spindle motor - Powerful enough to create a shower of chips when removing steel or any other type of exotic alloy! Geneva Drive Automatic Tool Changer - Can hold 21 CAT40 type holders - Change tools in 6 seconds! All movements are controlled by the main computer which monitors feedback on each gear motor. There is no hydraulic system in the tool changer which also gives the advantage of a simpler system for maintenance.CNC 88 Control Pendant - One of the most user-friendly controls made for CNC! All logic necessary for the operation of this machine is contained in the computer's software. The tactile keyboard also simplifies operations by giving the user positive feedback and response while entering commands or programming.Fadal VMC 4020HT Specs:Total Machine Exterior Dimensions: 116" x 87" x 95"Table Size: 47.94" x 20"Cutting Feed Rate .01"-150" [225" at 150%]Rapid Feed Rate 400"/MinMax Table Capacity 1000 lbs.Axis Drive Motor 1.8 HP DCX Axis 40"Y Axis 20"Z Axis 20"Spindle Nose to Table 4"-24"Spindle Center to Column 20"Spindle Motor 15/20HP, 11 kWSpindle Speed 40-10,000 RPM3 Phase Converter 45 Amps, 190-510 VAC
- You may not post replies
- You may not edit your posts
Forum Rules
