https://www.ebay.com/itm/183702702635
Spindle Motor Specifications :
Power : 5.5KW
Voltage : 220V
Current : 20A
Frequency : rate 400Hz max 600hz
Speed : 18000rpm
Cooling Type : Water-cooled
Joint of nose : BT30 Taper 45o , petal
Lubrication : Grease
weigth: 26kg
Diameter: 125mm
Lengt: 460mm
Air pressure: 6kg/cm2
- sale spindle atc bt30 2 pole 380V 300hz 18000rpm brand new
- Low cost spindle ATC BT30 3kw 4 pole 220V 400hz max 600hz 18000rpm
- Need Help!- Need help in setting up 2.2kw 220v 400Hz spindle with L&T Cx2000 VFD
- Newbie- ATC Bt30 7.5kw 380v spindle/220v 1 phase vfd availability
- Need Help!- Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
