- Parlec Parsetter TMM Series
Parlec Parsetter TMM Series 100
Description: CNC tool offset presetter capable of taking offsets up to 16" gage length. Main spindle taper is SK50 and comes with a SK40 adapter. 2 calibration probes- 1 for the SK50 and 1 for the SK40. Uses a dot-matrix printer to print out offset labels. Control panel functional and in great condition considering age and use.
Model: P10-1216
S/N: 213485-1299
Dimensions: Height 71" x Width 36" x Depth 31"
Power: 120V 60HZ
https://www.ebay.com/itm/323546405170
Parlec Parsetter TMM Series 2000
Description: CNC tool offset presetter capable of taking offsets up to 24" gage length. Main spindle taper is SK50 and comes with a SK40 adapter. 2 calibration probes- 1 for the SK50 and 1 for the SK40. Uses a dot-matrix printer to print out offset labels. Control panel functional and in great condition considering age and use. Printer button is worn off but still functions. There is a manual for operation of the Presetter.
Model: P20-2024
S/N: PA886-0202
Dimensions: Height 78" x Width 36" x Depth 31"
Power: 120V 60HZ
https://www.ebay.com/itm/323546407584
- You may not post replies
- You may not edit your posts
Forum Rules
