- 3 Yama Seiki GLS-2000-LYS machine packages, 2 with UR3 robot unloaders
For sale is a 2016 Yama Seiki
GLS 2000 LYS CNC turning center (live milling, Y axis, and Sub spindle)
~1050 Cut Hours. Machine is current capital equipment in our production facility so hours will continue to rise while for sale.
Machine is currently holding +/- .0002 on Aluminum and +/- .0004 on Stainless. No carbon steel, brass, copper, or plastic has been in the machine. Cabinets are clean and rust free.
https://s3.amazonaws.com/hpllc/Sales+...
Machine info / Build details
Factory built specs/options
1. FANUC 31I-T CONTROL WITH 10.4" COLOR LCD & DYNAMIC GRAPHIC DISPLAY
2. MANUAL GUIDE 0I CONVERSATIONAL PROGRAMMING
3. FANUC ALPHA SPINDLE & SERVO DRIVES
4. FANUC AC 15HP (CONT.), 20HP (30 MIN.), 25HP (PEAK) DUAL WINDING SPINDLE MOTOR
5. DIRECT BELT DRIVEN SPINDLE
6. MAIN SPINDLE RPM: GLS-2000L(MS/YS) - 20 ~ 1,500 ~ 4,500 RPM DUAL SPINDLE SPEED CONFIGURATION
7. MAIN SPINDLE CHUCK (INCLUDING ONE SET OF SOFT JAWS & ONE SET OF HARD JAWS): GLS-2000L(MS/YS) – 8 INCH 3-JAW THROUGH-HOLE (65MM) BIG-BORE POWER CHUCK
8. SUB SPINDLE RPM: 6000 RPM SINGLE SPINDLE SPEED CONFIGURATION
9. SUB SPINDLE CHUCK (INCLUDING ONE SET OF SOFT JAWS & ONE SET OF HARD JAWS):
TAIWAN MADE 5 INCH 3-JAW THROUGH-HOLE (31MM) POWER CHUCK
10. X/Z AXIS FANUC AC 4.0 HP SERVO MOTOR WITH ABSOLUTE ENCODER
11. Y AXIS TRAVEL +/- 35MM WITH FANUC AC 2.2 HP SERVO MOTOR [Y MODEL ONLY]
12. 12 STATION 12 LIVE SERVO INDEXING TURRET (ER-25)
WITH 1” OD AND 1-1/2” ID TOOLING SHANK
13. FULL CS AXIS CONTROL ON MAIN & SUB SPINDLE WITH DISK BRAKE
14. GUIDE WAY: LINEAR GUIDE WAYS
15. RENISHAW HPRA REMOVABLE PROGRAMMABLE IN-MACHINE TOOL SETTER
16. PARTS CATCHER & BAR FEEDER INTERFACE
17. GRUNDFOS 100 PSI HIGH PRESSURE COOLANT PUMP WITH ROLL-OUT COOLANT TANK
18. CHIP CONVEYOR WITH AUTO TIMER, HINGE TYPE, RIGHT DISCHARGE, DISCHARGE HEIGHT:47”(1200MM)
19. OIL SKIMMER
20. COOLANT FLUSH FOR SUB SPINDLE SLIDE WAY COVER 21. OPERATION & MAINTENANCE MANUALS, PARTS LIST, ELECTRICAL DRAWINGS, & FACTORY TEST REPORT
22. THREE COLOR OPERATION STATUS SIGNAL LIGHT TOWER
23. TOOL BOX WITH EMERGENCY MAINTENANCE ELECTRICAL PART PACKAGE
24. V15.0 TOOLING PACKAGE FOR GLS-1500LMS LYS & GLS-2000LMS LYS
25. 0 DEGREE LIVE TOOL HOLDERS (COLLET: ER-25) X2
26. 90 DEGREE LIVE TOOL HOLDERS (COLLET: ER-25) X2
27. SAFETY FEATURES: FULLY ENCLOSED GUARDING, DOOR INTERLOCK, HYDRAULIC PRESSURE SAFETY SWITCH, PROGRAM PROTECT, CHUCK CLAMP/UNCLAMP CONFIRMATION
28. BS-65L BAR FEEDER
Installations after delivery:
1) Factory (field) Integration of Servo bar loader ($15,000 value promotion with sale) Field integration ($1666.00)
2) Factory (field) integration of RENISHAW (automatic) tool setter ($1500 upgrade from included manual bolt in unit)
3) Install of UR3 Robot from Kienrich Industrial ($28,000)
4) Install of Chipblaster M30-70 by chipblaster ($10,000)
5) Install of OEM Yama Part Conveyor ($3000)
6) Install of Main & Sub Air Blows ($2500)
7) Factory Install of Tool Load Monitoring Software ($4000 + engineering and application setup)
8) Engineering and Application work for machine setup (control edits, installs, tool life monitoring, conveyor install, manual guide-i setup etc) done by local manufacturing consultants ($8300)
9) Auto - Door Install / Integration ($2500)
10) Kitagawa BB206 sub spindle chuck with adapter plate for 4.6" depth behind face of chuck @ 52mm spindle bore part ejector compatible ($7531.50)
11) Upgrade Fanuc 31I program memory to 4MB ($935)
12) Fanuc install memory upgrade ($300)
Standard Package tooling included plus the below
13) Extra double 1” stick turning holders ($630)
14) 1 Custom quad coolant through ¾” ID holder. ($1000)
15) 1 custom offset 1.5” ID drill holder ($1000)
16) 1.75” Miyano holders with coolant through mods (2) ($600)
17) Coolant through bushings for 1.75” Miyano holders ($700)
18) 1 Miyano double 1” stick holder compatible with machine. ($200)
19) 1 custom Miyano coolant through ER40 holder ($700)
20) 1, 90DEG high speed 1:3 WTO live tool ($5500)
21) 1, Heimatech radial ER20 1:3 live tool ($4950.00)
22) 1, Extra WTO Quickflex 90 degree Live holder ($3569)
23) 1, Extra Radial WTO Quickflex tool ($2090)
24) Mistaway with 3 re-washable aluminum filters and installation ($3000)
25) Upgraded way wash ($500)
Total of 8 live tools included with machine.
$94,765.50 upgrades- total sale value $244,765.5
Asking $170k not including freight or rigging. 2 Days Training on our production floor is complementary. Nearest airport is MSN . Pre-sale inspection by buyer and or local service company can be done at your expense with an appointment.
Asking $139,000 for the 3rd machine which is like this minus the auto door, radial 1:3 live tool, kitagawa through spindle chuck, and UR3 robot. The sub chuck on that machine is a kitagawa 5" I believe B205
Items that can be removed from package price are as follows:
* UR3 ROBOT -$14,000
* CHIPBLASTER M30-70 -$4,000
* Main & Sub chucks -$1500 / each
Machine package without these parts is $149k asking
email: manoftin2@yahoo.com with offers/ inquiries Haggling can be conducted via email, we are an active shop and are very work focused.
- You may not post replies
- You may not edit your posts
Forum Rules
