- Prolight Mini Mill for retrofit-full enclosure, mist system, etc!
Hi everyone. I am selling my Prolight mini mill,see link below. This a great little mill. Can easily cut non ferrous metals, and even some steel. I had retrofitted a full Teknic servo motor control since the original prolight control was fried, but pulled it off for another project. I rebuilt the spindle with new NSK bearings, replaced all of the pulleys with Kevlar ones, and replaced all of the limit switches. It's got a full enclosure made out of 8020, and the base table is welded steel.
All someone would need to add are nema steppers and a control. I even have some steppers or the original servos if someone is interested. Also have some other misc stuff like a power supply, electrical cabinet and perfect machinists vise.
https://www.ebay.com/itm/LIGHT-MACHI...sid=m570.l1313
Re: Prolight Mini Mill for retrofit-full enclosure, mist system, etc!
Hello, I have a Prolight 1000 machine and my servo motor is starting to have issues.... so I am looking to replace the motor. Would you happen to have one?
Thanks...
Kent
- You may not post replies
- You may not edit your posts
Forum Rules
