- Brother TC225 tapping machining center
Brother TC225 machining center. runs under existing "non gcode" control just fine, and has a Linuxcnc retrofit that could be plugged in and finished. could be a big level up from a tormach or the like if you the energy to finish the control swap.
Located in Toronto.
I have 2 brothers, and my shop is getting torn down for condos next week... so, hard to keep both around. Give it a good home!
https://www.ebay.ca/itm/323132984304
- You may not post replies
- You may not edit your posts
Forum Rules
