Problem G32 doesn't do the right pitch
Results 1 to 7 of 7
Thread: G32 doesn't do the right pitch
    Member geppo_it's Avatar
    Apr 2019
    Default G32 doesn't do the right pitch
    Good morning Tom,
    today I did my first threading using the G-Code G32. At the beginning it seams it working fine but at real it didn't.
    The follow instruction:
    G32 Z-20 F1.25
    it doesn't have a pitch of 1.25 mm but 1.34 mm, obviously this is not correct.
    Do you have any idea why I got such a big pitch error?
    Please tell me what you need to check regarding the hardware and software setup
    Beppe
    Member TomKerekes's Avatar
    May 2006
    Default Re: G32 doesn't do the right pitch
    Hi Beppe,
    Do you have an encoder on the Spindle? How many counts/rev? Have you verified it counts correctly? What are your Tool Setup | Trajectory Planner | Threading/Spindle Settings?
    Regards
    TK http://dynomotion.com
    Apr 2019
    hi Tom,
    yes I have an encoder on spindle, 1000 counts/rev. Now is night here, tomorrow morning i will make a screenshot of Spindle Setting into Tool Setup and I will post it here. Do you need something else to check?
    As for the correct functioning of the encoder I really don't know what to do... Advices??
    Beppe
    May 2006
    Have you verified it counts correctly? For example if you zero the encoder and physically mark the spindle then run it for a while and position it to some multiple of 1000 i.e. 100,000 is the spindle physically in the same place?
    Regards
    Apr 2019
    hi Tom,
    today I checked if the Spindle encoder counts correctly and it does.
    Attached is the screenshot of my Spindle configuration
    Beppe
    Attached Thumbnails Attached Thumbnails G32 doesn't do the right pitch-tool-setup-screenshot-jpg
    May 2006
    Hi Beppe,
    That looks correct.
    Is your Z Axis calibrated correctly?
    Is the Feed Rate Override set to 1.0?
    What Spindle RPM?
    Please post your complete GCode.
    Please post your Initialization C Program.
    Is it consistent? If you change the Spindle Speed is it still consistent?
    What Version are you running?
    Regards
  7. #7
    Apr 2019
    hi Tom,
    at the same time I was reading your question:
    I understood where the mistake was. Since I didn't think the G32 was affected by FRO, I didn't pay any attention to it.
    In my system the FRO is function of a potentiometer, therefore FRO=1 is approximately halfway through its rotation and
    is not a fixed position: checking better, I realized that I had carried out all the threading tests with a FRO=1.08. Which justifies the pitch error I got.
    By setting FRO=1 the threading is perfect
    Thanks for your patience
    best regards
    Beppe
