Need Help! Using two KStep board
Results 1 to 2 of 2
Thread: Using two KStep board
    Member RuslanRobot's Avatar
    May 2019
    Default Using two KStep board
    Good day!
    We are going to use two KStep board in one mashine (using one KFLOP).
    1. How to conect KFLOP with second KStep board? (what JP we need to use?)
    2. What additional connecting wire we need to use? Can we order it in dynomotion?
    3. We are going to use two stepmotors NEMA 34 - it is 5,6 A. KStep has limit 5 A. Is it possible to use NEMA 34 with KStep?
    Member TomKerekes's Avatar
    May 2006
    Default Re: Using two KStep board
    See here.
    If you order the boards together or tell us when ordering how they will be connected we include the inter board cables.
    You should be able to run the motors at 5A. Holding and low speed torque will be less but higher speed torques will likely be the same which is where it is mostly needed.
    Regards
    TK http://dynomotion.com
