Need Help! Lathe conversion
Results 1 to 4 of 4
Thread: Lathe conversion
    Default Lathe conversion
    Hi
    I will convert a Bernardo BQV550 to CNC.
    Like to use KFlop + Kstep for controller
    How to connect an ancoder for Spindle to KFlop?
    Which Encoder should be used?
    Is it possible to run 2 KFlops in one PC, 1 for milling machine (allready exists) and a second for the lathe?
    BR
    Gerhard
    Member TomKerekes's Avatar
    May 2006
    Default Re: Lathe conversion
    Hi Gerhard,
    Its best to use a differential encoder. But KFLOP+KStep doesn't have any differential encoder inputs. So you might use a 3rd party differential receiver such as this. This might be then connected to a KFLOP Single ended Encoder input ie JP5. Encoder resolution should be such that at max RPM KFLOP's maximum cout rate of 1 million quadrature counts/sec is not exceeded.
    That should be possible. When launching KMotion/KMotionCNC which KFLOP to be used needs to be specified as a command line parameter USB Location ID. See here.
    Regards
    TK http://dynomotion.com
    Hi Tom,
    is the second KFlop also possible if I use your MACH3 plugin?
    BR
    Gerhard
    May 2006
    No. Mach3 is obsolete and unsupported. Consider using our free KMotionCNC.
    Regards
Lathe conversion
Lathe conversion
