Build Thread DAC Spindle Speed Feedback - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: DAC Spindle Speed Feedback
  1. #21
    Member TomKerekes's Avatar
    May 2006
    Default Re: DAC Spindle Speed Feedback
    Hi Sean,
    You might try lower P gain or lower Acceleration to reduce overshoot.
    Adding D gain with a 2nd order Low pass filter of maybe 200Hz Q=1.4
    Regards
    TK http://dynomotion.com
  2. #22
    Activation process sean69_uk's Avatar
    Jul 2018
    Tom
    Thank you so much for the help , i think i have it where it is workable , now to set it up in Kmotion.exe
    i have set up M3,M4,M5 and S in the tool setup , using your example in the CSS folder and the Motor starts and changes direction . but it doesn't Stop or display speed.
    i have the FACTOR set at 50 holes*4 edges = 200/60 or should i be using a different format as i read somewhere 1=3750 or 20157 = 3750
    i think i have read so many posts and guides now that i am confusing myself.
    If i use the zero button in step/response screen to stop the motor it goes to -2047 = -9.995v in the analogue screen and then when i start the motor again it ramps to zero then the speed i want , which is causing some of the the slow motor start
    regards
    Sean
  3. #23
    May 2006
    Hi Sean,
    It seems you moved to a new Thread here.
    Regards
