Need Help! KFLOP Servo alarm sensing
Results 1 to 3 of 3
Thread: KFLOP Servo alarm sensing
    Apr 2004
    Wisconsin, USA
    Default KFLOP Servo alarm sensing
    Just for some background I am retrofitting a Tree Journeyman 325 Mill.
    So far most of the project is going better then expected. I am using AASD-30A 1.5KW servos and a Lepond 7.5 KW VFD to drive the original Fanuc spindle Motor.
    The machine runs good and I can easily get rapids in 400IPM range.
    There are two safety issues I am having:
    1. When I shut down the computer after initializing, the servos stay enabled. I need them to disable once the software is shut down.
    2. I need the control to sense if one of the drives has a fault output that goes low and stop all motion.
    I changed the setting in the main program to Setbit (48) to enable the drives during INIT.
    I am using bits 1050-1053 on a Konnect to monitor the servo ready signals from the drives.
    I have scoured the documentation and cannot seam to find a solution is there something I am missing?
    sick minds demand sick toys!
    Apr 2004
    Wisconsin, USA
    Default Re: KFLOP Servo alarm sensing
    To follow up on this post. I did get the system to monitor the servo ready signals and shut it down if it detected a low signal. I just used a simple IF, ELSE command to monitor the input bits and Disable the appropriate axis.
    I'm still trying to find a way to disable the servos if the PC freezes or is shutdown.
    Member TomKerekes's Avatar
    May 2006
    Hi Crasher,
    See the WatchdogStatusRequests.c example.
    HTH
    Code:
    #include "KMotionDef.h"
    void ServiceWatchdogStatus(void);
    void WatchdogTripped(void);
    void WatchdogOK(void);
    #define WATCHDOG_DELAY 5.0 // seconds after host stops to Trigger
    // for testing
    main()
        for (;;)
            WaitNextTimeSlice();
            ServiceWatchdogStatus();
    // Watchdog Trips after all host applications stop requesting status
    // Watchdog OK is called when communication and status requests Resume
        static int Alive=FALSE;
        static int PrevStatusRequestCounter=-1;
        static double WatchdogTime=0;
        double T=Time_sec();
        // check if Host is requesting Status
        if (StatusRequestCounter != PrevStatusRequestCounter)
            // yes, save time
            WatchdogTime = T + WATCHDOG_DELAY;
            PrevStatusRequestCounter=StatusRequestCounter;
            if (!Alive) WatchdogOK();
            Alive=TRUE;
        else
            if (T > WatchdogTime)  // time to trigger?
                if (Alive) WatchdogTripped();
                Alive=FALSE;
        ClearBit(47);  // KFLOP LED off
        Delay_sec(1);
        SetBit(47);
        Delay_sec(1);
        ClearBit(46);  // KFLOP LED off
        Delay_sec(1);
        SetBit(46);
        Delay_sec(1);
    Regards
    TK http://dynomotion.com
