Need Help! Manual control arrows - how to make inactive?
Results 1 to 3 of 3
Thread: Manual control arrows - how to make inactive?
    Member RuslanRobot's Avatar
    May 2019
    Default Manual control arrows - how to make inactive?
    Please help me.
    How do I make the manual control arrows on the KMotionCNC panel inactive (turn off)? See the photo - circled in red. So that I can then turn it on if necessary.
    I need it in order that the operator does not accidentally press button unnecessary.
    Attached Thumbnails Attached Thumbnails Manual control arrows - how to make inactive?-1-jpg
    May 2019
    Default Re: Manual control arrows - how to make inactive?
    I find!
    Thanks!
    Member TomKerekes's Avatar
    May 2006
    The Jog Buttons do automatically disable while a Job is running. It's not common to want do disable them when the machine is idle. We don't have a command to do that. We have commands to do the opposite. To re-enable them while a Job is running. Some MCodes might require the Operator to Jog for some purpose. These commands will allow this:
    #define PC_COMM_ENABLE_JOG_KEYS 37 // Allow User to Push Jog Buttons while JOB is running
    #define PC_COMM_DISABLE_JOG_KEYS 38 // Disable allowing User to Push Jog Buttons while Job is Running
    Otherwise the only solution I can think of would be to switch to a custom screen without the buttons present or functional. Or to change the KMotionCNC Source code.
    Regards
    TK http://dynomotion.com
