KmotionCNC DRO font alignment issue after font change
Results 1 to 3 of 3
Thread: KmotionCNC DRO font alignment issue after font change
    May 2017
    Default KmotionCNC DRO font alignment issue after font change
    Sorry, this probably seems a bit type A and unimportant to worry about, but I've been making a custom UI for KmotionCNC with the Screen Editor and ran into an issue after changing the font on the axis DRO section. After the font change, the font wants to center a bit when the numbers are changing rather than staying fixed like before. For example, the "X" in the X axis DRO indents a tad and the coordinate number indents a tad from the right as well, centering itself in the box. I'd really prefer the X never move and that the decimals stay aligned like before the font change. I'm a bit committed to the font now because I've invested a ton of time creating custom button bitmaps using that font, so I'm hoping I can tweak this. Any ideas?
    Member TomKerekes's Avatar
    May 2006
    Default Re: KmotionCNC DRO font alignment issue after font change
    It seems you double posted this question here.
    Regards
    TK http://dynomotion.com
    May 2017
    Quote Originally Posted by TomKerekes View Post
    Sorry for the repeat post. I figured I'd pop it into both forums in case different folks kept up with the separate forums. Thanks again for the help!
