There are 4 quadrature transitions in a complete quadrature cycle. So that should be 10000 counts/rev. To verify rotate the spindle one rev and see how much the position changes. If you put 10000 in the KMotionCNC | Tool Setup | Trajectory Planner | Threading Screen KMotionCNC should display RPM correctly.I now have a question about calculating the Factor of my Spindle so I can use an axis for monitoring the RPM. The encoder I'm using is a BEI RIH 22 incremental encoder. It has a resolution of 2500 cycles, I guess that means counts per/rev? How do I calculate, whatever needs to be calculated, to update my C-program for the correct RPM?
Its not clear what you are trying to do. KMotionCNC will already display Spindle RPM.How do I also change the letter of the axis or insert a new window in screen editor. I watched the Youtube video of entering a new window to see real time feeds, but I couldn't catch how the window was actually put in.
