starting my C program, any guidance would be appreciated. - Page 2
Page 2 of 11 FirstFirst 12345 ... LastLast
Results 21 to 40 of 215
Thread: starting my C program, any guidance would be appreciated.
  1. #21
    Member TomKerekes's Avatar
    May 2006
    Default re: starting my C program, any guidance would be appreciated.
    You aren't answering questions so it makes it hard to have progress.
    Which KFLOP axis is your Z axis? Does your Z axis work in KMotion.exe?
    Regards
    TK http://dynomotion.com
  2. #22
    Member Gunmachinist's Avatar
    May 2020
    Quote Originally Posted by TomKerekes View Post
    0 is my Z axis and works when i run it in KMotion but not KMotioncnc.
  3. #23
    May 2020
    I don't know why, but they are all working/counting correctly now. I couldn't get it last night, but it's working now. Freaking gremlins!
  4. #24
    May 2020
    I'm trying to run G code to test axis movement and keep getting (Gcode error Gcode Aborted) seemes to happen on G0.
  5. #25
    May 2006
    Most likely the Velocities and Accelerations in KFLOP are set too high.
    Regards
  6. #26
    May 2020
    So do I need to reduce that in Kmotion or in KmotionCNC (Trajectory Planner) What should a normal Velocity and Acceleration look like. Mine are currently about 50000 and 500000.
  7. #27
    May 2006
    KMotion.exe used to set, test, and create the Init C Program control G0 Rapid rates. The settings are dependent on your system. See also here.
    A common problem is to have too high of settings and not realize it when only testing small moves. This is like stating your car can go 300mph but then only test it in your driveway.
    Regards
  8. #28
    May 2020
    I reduced the V and A 20% in KMotion and then updated the C code file. I also changed the KMotion CNC Trajectory Planner. The G code still will not run and now stops at G01.
    Attached Thumbnails Attached Thumbnails starting my C program, any guidance would be appreciated.-screenshot-41-jpg   starting my C program, any guidance would be appreciated.-screenshot-40-jpg
  9. #29
    May 2006
    Hi Gunmachinist,
    Please put more effort into your responses otherwise we don't know what you are doing and can't help.
    Please determine your Velocities, Accelerations, and Jerks as described here. Describe what you did and post the results. Test big enough moves that reach full velocity and post them.
    Regards
  10. #30
    May 2020
    Hi Gunmachinist,
    I have read and reread Dynomotion wiki. I have re-tuned the servos and after tuning I decreased Velocity, and Acceleration by 20% and updated my C program. X and Y axis are at 40000 Velocity and 400000 Acceleration, Z is 32000, and 320000. Jerk is set at 100000 for all three axes. I entered the information in Kmotion CNC for XYZ axis and attempted to run a short program just to verify that the axis would work, and I get the message Gcode error/Gcode aborted. I've tried different G code programs with the same results. At this point I dont know what more to include, It may help if you guys would ask questions.
    Here is C code as it is now.
    #include "KMotionDef.h"
    // Default Initial Configuration for 3 Axis Analog DAC Servo with encoder feedback
    // Note Low Gains, Limited Max Limits, No Limit Options, No Soft Limits,
    // Large allowed Following Error, No Feed Forward, No Filters, etc
    void main()
    SetBit(152); // enable AMPS
    SetBit(157);
    SetBit(158);
    ch0->InputMode=ENCODER_MODE;
    ch0->OutputMode=DAC_SERVO_MODE;
    ch0->Vel=32000;
    ch0->Accel=320000;
    ch0->Jerk=100000;
    ch0->P=26.68;
    ch0->I=0.0001;
    ch0->D=32.332;
    ch0->FFAccel=0.0001;
    ch0->FFVel=0.0009;
    ch0->MaxI=2047;
    ch0->MaxErr=100;
    ch0->MaxOutput=2047;
    ch0->DeadBandGain=3;
    ch0->DeadBandRange=0;
    ch0->InputChan0=0;
    ch0->InputChan1=1;
    ch0->OutputChan0=0;
    ch0->OutputChan1=1;
    ch0->MasterAxis=-1;
    ch0->LimitSwitchOptions=0x11f;
    ch0->LimitSwitchNegBit=136;
    ch0->LimitSwitchPosBit=136;
    ch0->SoftLimitPos=1e+30;
    ch0->SoftLimitNeg=-1e+30;
    ch0->InputGain0=1;
    ch0->InputGain1=1;
    ch0->InputOffset0=0;
    ch0->InputOffset1=0;
    ch0->OutputGain=1;
    ch0->OutputOffset=0;
    ch0->SlaveGain=1;
    ch0->BacklashMode=BACKLASH_OFF;
    ch0->BacklashAmount=0;
    ch0->BacklashRate=0;
    ch0->invDistPerCycle=1;
    ch0->Lead=0;
    ch0->MaxFollowingError=10000000;
    ch0->StepperAmplitude=250;
    ch0->iir[0].B0=1;
    ch0->iir[0].B1=0;
    ch0->iir[0].B2=0;
    ch0->iir[0].A1=0;
    ch0->iir[0].A2=0;
    ch0->iir[1].B0=1;
    ch0->iir[1].B1=0;
    ch0->iir[1].B2=0;
    ch0->iir[1].A1=0;
    ch0->iir[1].A2=0;
    ch0->iir[2].B0=1;
    ch0->iir[2].B1=0;
    ch0->iir[2].B2=0;
    ch0->iir[2].A1=0;
    ch0->iir[2].A2=0;
    ch1->InputMode=ENCODER_MODE;
    ch1->OutputMode=DAC_SERVO_MODE;
    ch1->Vel=40000;
    ch1->Accel=400000;
    ch1->Jerk=100000;
    ch1->P=22;
    ch1->I=0.0001;
    ch1->D=12;
    ch1->FFAccel=0.0001;
    ch1->FFVel=0.0006;
    ch1->MaxI=2047;
    ch1->MaxErr=100;
    ch1->MaxOutput=2047;
    ch1->DeadBandGain=4;
    ch1->DeadBandRange=0;
    ch1->InputChan0=1;
    ch1->InputChan1=1;
    ch1->OutputChan0=1;
    ch1->OutputChan1=1;
    ch1->MasterAxis=-1;
    ch1->LimitSwitchOptions=0x11f;
    ch1->LimitSwitchNegBit=138;
    ch1->LimitSwitchPosBit=138;
    ch1->SoftLimitPos=1e+09;
    ch1->SoftLimitNeg=-1e+09;
    ch1->InputGain0=1;
    ch1->InputGain1=1;
    ch1->InputOffset0=0;
    ch1->InputOffset1=0;
    ch1->OutputGain=1;
    ch1->OutputOffset=0;
    ch1->SlaveGain=0;
    ch1->BacklashMode=BACKLASH_OFF;
    ch1->BacklashAmount=0;
    ch1->BacklashRate=0;
    ch1->invDistPerCycle=1;
    ch1->Lead=0;
    ch1->MaxFollowingError=10000000;
    ch1->StepperAmplitude=250;
    ch1->iir[0].B0=1;
    ch1->iir[0].B1=0;
    ch1->iir[0].B2=0;
    ch1->iir[0].A1=0;
    ch1->iir[0].A2=0;
    ch1->iir[1].B0=1;
    ch1->iir[1].B1=0;
    ch1->iir[1].B2=0;
    ch1->iir[1].A1=0;
    ch1->iir[1].A2=0;
    ch1->iir[2].B0=1;
    ch1->iir[2].B1=0;
    ch1->iir[2].B2=0;
    ch1->iir[2].A1=0;
    ch1->iir[2].A2=0;
    ch2->InputMode=ENCODER_MODE;
    ch2->OutputMode=DAC_SERVO_MODE;
    ch2->Vel=40000;
    ch2->Accel=400000;
    ch2->Jerk=100000;
    ch2->P=6;
    ch2->I=0.0001;
    ch2->D=6;
    ch2->FFAccel=0.0001;
    ch2->FFVel=0.0009;
    ch2->MaxI=2047;
    ch2->MaxErr=1000;
    ch2->MaxOutput=2047;
    ch2->DeadBandGain=3;
    ch2->DeadBandRange=0;
    ch2->InputChan0=2;
    ch2->InputChan1=1;
    ch2->OutputChan0=2;
    ch2->OutputChan1=1;
    ch2->MasterAxis=-1;
    ch2->LimitSwitchOptions=0x11f;
    ch2->LimitSwitchNegBit=137;
    ch2->LimitSwitchPosBit=137;
    ch2->SoftLimitPos=1e+30;
    ch2->SoftLimitNeg=-1e+30;
    ch2->InputGain0=1;
    ch2->InputGain1=1;
    ch2->InputOffset0=0;
    ch2->InputOffset1=0;
    ch2->OutputGain=1;
    ch2->OutputOffset=0;
    ch2->SlaveGain=1;
    ch2->BacklashMode=BACKLASH_OFF;
    ch2->BacklashAmount=0;
    ch2->BacklashRate=0;
    ch2->invDistPerCycle=1;
    ch2->Lead=0;
    ch2->MaxFollowingError=10000000;
    ch2->StepperAmplitude=250;
    ch2->iir[0].B0=1;
    ch2->iir[0].B1=0;
    ch2->iir[0].B2=0;
    ch2->iir[0].A1=0;
    ch2->iir[0].A2=0;
    ch2->iir[1].B0=1;
    ch2->iir[1].B1=0;
    ch2->iir[1].B2=0;
    ch2->iir[1].A1=0;
    ch2->iir[1].A2=0;
    ch2->iir[2].B0=1;
    ch2->iir[2].B1=0;
    ch2->iir[2].B2=0;
    ch2->iir[2].A1=0;
    ch2->iir[2].A2=0;
    EnableAxis(0);
    EnableAxis(1);
    EnableAxis(2);
    DefineCoordSystem(2,1,0,-1);// define XYZA axes
    Attached Thumbnails Attached Thumbnails starting my C program, any guidance would be appreciated.-screenshot-45-jpg   starting my C program, any guidance would be appreciated.-screenshot-46-jpg   starting my C program, any guidance would be appreciated.-screenshot-47-jpg   starting my C program, any guidance would be appreciated.-screenshot-48-jpg
    starting my C program, any guidance would be appreciated.-screenshot-49-jpg
  11. #31
    May 2006
    Actually I see now the Following Errors are set huge so regardless of how bad the tuning is you wouldn't get any error. It must be something unrelated to tuning.
    I see "Launch on Power up" is set so you have modified KFLOP. Please remove those changes by re-flashing "New Version"
    I can't think of why you would get a "G Code Error" without some other message. Is there any? You might try simulating the GCode.
    Maybe the installation is messed up. You might reinstall it after making a copy of your current installation.
    Regards
  12. #32
    May 2020
    also.
    The max following errors in the configuration or step response screen? I reflashed
    No other message that gcode error/gcode aborted.
    I assume your talkning about KMotion and KMotion CNC?
  13. #33
    May 2006
    also.
    huh?
    Configuration Screen
    I reflashed
    And?
    Yes, but actually the full installation on the PC
    Regards
  14. #34
    May 2020
    huh?
    Not sure where that came from.
    And?
    I'm working on the Max following errors to get them down. When I started it basically stopped the axis from working. How low should the Max following error be?
  15. #35
    May 2006
    Observe what your following errors are under normal conditions and set to a larger value.
    Regards
  16. #36
    May 2020
    I did some work with tuning my axis and have been able to get the Max Following Errors down, but when trying to run G-code I still get and the same error code. Here is my current screen shots of each axis. I ve also been playing with TripsWPF, and could you explain how I'm supposed to use the check all?
    Attached Thumbnails Attached Thumbnails starting my C program, any guidance would be appreciated.-screenshot-51-jpg   starting my C program, any guidance would be appreciated.-screenshot-52-jpg   starting my C program, any guidance would be appreciated.-screenshot-53-jpg
  17. #37
    May 2006
    It seems you miss-understood my post #31 where I tried to explain following error was not the problem and to try other things. So then you focused on following error and ignored the other suggestions.
    Its good your playing with TripsWPF. Hopefully you get a better understanding of Velocity, Acceleration, Jerk, and distance.
    Regarding TripsWPF Check All button: You wouldn't use it. Its for our use to apply many sets of parameters to TripsWPF to check it is able to solve them all correctly.
    Regards
  18. #38
    May 2020
    Ok, Max following error, and tuning were my last resort after I reflashed and reinstalled KMotion. Those were the only things you mentioned so I tried all of them. If tuning isn't the problem with why im getting the G-code error then then Im guessing it's in setting up KMotionCNC trajectory planner. Do you see anything wrong in trajectory planner in post 30? What else could be the reason all I get is gcode aborted message?
  19. #39
    May 2020
    Oops
  20. #40
    May 2020
    Unhappy re: starting my C program, any guidance would be appreciated.
    I guess I dont know what I'm looking for with Trips, because it is not giving me good results when entering the information in KMotion. When getting settings in Trips what am I supposed to be looking for, do you have an example of what a good looking Trips looks like?
    Attached Thumbnails Attached Thumbnails starting my C program, any guidance would be appreciated.-screenshot-54-jpg   starting my C program, any guidance would be appreciated.-screenshot-55-jpg
