I did my changes to MPGServiceSmoothHardwareEncFilteredRev3 and I am getting an error (; expected) when there is already a ; WTF
Code:
#include "KMotionDef.h"
// Example Function as "smooth" MPG motion example
// which makes use of the exponential motion command.
// Additionally double Filtered to be very smoot with limited Jerk
#define MPG_INPUT_AXIS 2 // Axis used to read hardware encoder (not necessarily the encoder channel)
#define QA 19 // define to which IO bits the AB signals are connected
#define QB 20
#define TAU 0.01 // smoothness factor (Low Pass Time constant seconds for MoveExp)
#define TAU1 0.015 // smoothness factor (Low Pass Time constant seconds for pre filter 1)
#define TAU2 0.015 // smoothness factor (Low Pass Time constant seconds for pre filter 2)
#define FINAL_TIME 1.0 // Set final dest after this amount of time with no change
#define FACTOR1 16
#define FACTOR10 17
#define FACTOR100 18
#define SELECTX 21
#define SELECTY 22
#define SELECTZ 23
#define SELECTA 24
void ServiceMPG(void)
static int Pos, FirstTime= 1;
static int InMotion = 0,Axis,LastAxis = -1;
static double LastChangeTime = 0,Target,Factor = 0;
static double Target1, Target2, K1, K2, K1M, K2M;
int Change1, NewPos;
main()
if (FirstTime);
K1 = exp(-2 * TIMEBASE / TAU1); // filter coefficients
K2 = exp(-2 * TIMEBASE / TAU2);
K1M = 1.0 - K1;
K2M = 1.0 - K2;
FirstTime = FALSE;
Change1 = NewPos - Pos;
Pos = NewPos;
if (ReadBit(FACTOR1)) // is X1 selected?
Factor = 4;
else if (ReadBit(FACTOR10)) // is X10 selected?
Factor = 20;
else if (ReadBit(FACTOR100)) // is X100 selected?
Factor = 40;
else
Factor = 0.0;
if (ReadBit(SELECTX)) // is x selected?
Axis = 0;
else if (ReadBit(SELECTY)) // is y selected?
Axis = 1;
else if (ReadBit(SELECTZ)) // is z selected?
Axis = 2;
else if (ReadBit(SELECTA)) // is A selected?
Axis = 3;
// Feedhold fully stopped ??
if (CS0_StoppingState == 4 && InMotion)
Change1 = 0; // ignore any MPG change
Jog(LastAxis, 0);
InMotion = FALSE;
// check if the Axis just changed or we have been
// converging to the target for a long time
if (Axis != LastAxis || (InMotion && Time_sec() > LastChangeTime + FINAL_TIME))
if (InMotion)
Move(LastAxis, Target1); //finalize any motion
LastAxis = Axis;
InMotion = FALSE;
if (Change1) // did we move?
if (!InMotion)
Target = Target1 = Target2 = chan[Axis].Dest;
Target1 += Change1 * Factor;
LastChangeTime = Time_sec();
InMotion = TRUE;
if (InMotion) // If moving
if (Target1 > chan[LastAxis].SoftLimitPos)
Target1 = chan[LastAxis].SoftLimitPos;
if (Target1 < chan[LastAxis].SoftLimitNeg)
Target1 = chan[LastAxis].SoftLimitNeg;
Target2 = Target2 * K1 + Target1 * K1M;
Target = Target * K2 + Target2 * K2M;
MoveExp(Axis, Target, TAU);
