4th Axis With Argon Drive - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: 4th Axis With Argon Drive
  1. #21
    May 2012
    canada
    Default Re: 4th Axis With Argon Drive
    Here is my code to clamp:
    Code:
    #include "KMotionDef.h"
    main()
    	Delay_sec(0.25); // wait for everything to stop
    	ch3->MaxOutput=1;  // reduce max gain
    	ch3->I=0.0;	// reduce integrator
    	SetBit(53); // turn on brake
    	while (!ReadBit(1052)) WaitNextTimeSlice(); // Wait for clamped signal
    And here is the code to unclamp:
    Code:
    main()
    	ClearBit(53); // turn off brake
    	while (!ReadBit(1053)) WaitNextTimeSlice(); // Wait for unclamped signal
    	ch3->MaxOutput=2000;  // increase max gain
    	ch3->I=0.010;	// increase integrator
    I just configured my M30 to unclamp so it unclamps at the end of every program, and you will also want to do the same thing for your halt/reset button. So anytime im not running g-code, its unclamped. If I ever need to do some very heavy hogging with the MPG (not likely) ill just use the M code in MDI to reclamp.
  2. #22
    Member Need TECH Help!'s Avatar
    Dec 2007
    Hi Murray,
    That is the same code i made minus the "disabling" of servo.
    The M30 config is a simple solution, thanks
    Troy
    www.tsjobshop.com, www.homecncstuff.elementfx.com
