Later you will set the resolution in KMotionCNC so that when you command some distance in inches or mm it moves the correct amount. But for now it is to allow us to put the errors and speed into perspective. For example your last plot had errors of about 100 counts. So that is 100/8000 = 0.0125 inches.I think my problem is I'm unsure where to apply these numbers
ok its helpful if you tell us when you make such changes.All of my previous test/findings were with the servos disconnected from the table playing around with numbers attempting to learn what did what. I connected the X axis yesterday to the table and the above screen print was a result of the table connected and a load placed on the X servo motor.
Start off making fairly slow moves such as 1 inch per second. This would be 8000 counts/secHow do I find the start of my Motion Profile Tuning Parameters?
Also at fairly low accelerations. In order to accelerate to that speed in 1/2 second that would be 16000 counts/sec^2
Jerk is not really important at early stages so set it to a large value such as 1000000 counts/sec^3
Correct as a starting point.I get that the V Feedforward would be 0.00045 if D gain is 5.
I don't understand what you mean.I understand that with the 8000 counts/inch = Measurement size.
