is the Dynomotion controll as confusing as it seems? - Page 3
Page 3 of 8 FirstFirst 123456 ... LastLast
Results 41 to 60 of 158
Thread: is the Dynomotion controll as confusing as it seems?
  1. #41
    Member Gunmachinist's Avatar
    May 2020
    Quote Originally Posted by TomKerekes View Post
    Hi Gunmachinist,
    Its not clear you understand you need Motor Drives (Amplifiers) to drive your motors. Do you?
    The first step should be to not use KFLOP/Kanalog at all and test your Amplifiers as described here.
    That sounds mostly wrong. Please don't power up the system until you understand what you are doing or you will likely damage another set of boards.
    Ok, I see im missing a few items. Wasn't aware I needed an amplifier to run the servos. It would probably help if someone started a thread with pictures of varrious setups.
    When it comes to electrical work, I like to draw with crayons and drool on myself.
  2. #42
    Member TomKerekes's Avatar
    May 2006
    Default Re: is the Dynomotion controll as confusing as it seems?
    Earlier I asked if you have Motor Drives and Power Supply and you replied "yes". But it seems we miss communicated.
    There are lots of build Threads such as this. So the first step will be for you to figure out if you have Amplifiers or not.
    Regards
    TK http://dynomotion.com
  3. #43
    May 2020
    Thanks for all the help, I'm just highly electricaly dumb.
  4. #44
    Dec 2013
    Quote Originally Posted by Gunmachinist View Post
    Please post a few pictures of your control panel. Maybe we can help.
    Jim Dawson
    Sandy, Oregon, USA
  5. #45
    May 2020
    Quote Originally Posted by Jim Dawson View Post
    Will do, just as soon as I get some servo amplifiers.
  6. #46
    Dec 2013
    What happened to the original drives (servo amplifiers)?
    Jim Dawson
    Sandy, Oregon, USA
  7. #47
    May 2020
    I assume your talking about the original Anilam system drives. I couldn't get them to work so I scrapped the hole system and started over, I was just a little confused as to what all goes into creating a new system. Oh, well best way to learn is by doing, and doing again..and again.
  8. #48
    Dec 2013
    Have you decided on what drives you drives you are going to get?
    Jim Dawson
    Sandy, Oregon, USA
  9. #49
    May 2020
    I found Advanced Motion Controls 12A8K on ebay for cheap, so Im going to give it a shot.
  10. #50
    May 2020
    Heres a picture of my control cabinet and the servo amp im using. The servos I have are SSI PT402 servos, but I am unable to find any information on them. I have identified the power, neutral, and ground; but there is a white and black I cant ID.
  11. #51
    May 2020
    Heres the pic, cabinet pic is actually upside down.
    Attached Thumbnails Attached Thumbnails is the Dynomotion controll as confusing as it seems?-20200710_100053-jpg   is the Dynomotion controll as confusing as it seems?-20200710_103722-jpg
  12. #52
    Dec 2013
    Could the black & white be the tach wires?
    Jim Dawson
    Sandy, Oregon, USA
  13. #53
    May 2020
    I think so, that or reference wires. I don't suppose It would damage the drive if I tested by wiring it and testing.
  14. #54
    Jan 2012
    According to an ebay post I found for those servo motors, it claims they are the same as "402CNSP0S72"
    This might be the data sheet http://www.telusplanet.net/public/sh...00R400F560.pdf
  15. #55
    Dec 2013
    This data sheet might be helpful to you http://servosystems.com/pdf/amc/25a8.pdf
    Jim Dawson
    Sandy, Oregon, USA
  16. #56
    May 2020
    cwatson1982
    Thanks, I've been all over the net and couldn't find anything.
  17. #57
    May 2020
    Thanks Jim.
  18. #58
    May 2006
    Assuming:
    and this:
    and this, the motor specs mght be :
    C402-3 ??
    which is specified here:
    is the Dynomotion controll as confusing as it seems?-c402-3-motor-png
    The 80V amplifier would then max out the RPM somewhere under:
    80V / Kv = 80V /24.37 x 1000 = 3283 RPM
    Looks like the current should be limited to 11 Amps.
    HTH
    Regards
  19. #59
    May 2020
    I'm not sure these are the same that came with the boss. I believe the machine I have was retrofitted around 1992 +/-. Here is a pic of the servos and machine so you get an idea of what im working with.
    Attached Thumbnails Attached Thumbnails is the Dynomotion controll as confusing as it seems?-20200505_111708-jpg   is the Dynomotion controll as confusing as it seems?-20200628_170235-jpg
  20. #60
    May 2020
    Assuming:
    and this:
    C402-3 ??
    HTH
    Ok, According to the specs of the control I'm using I should be supplying 80V. The Advanced Motion Controls 12A8K max amp at 12A should be perfect considering the mill max RPM only goes up to 4000. So, It looks like I'm headed in the right direction? Is their a way to step down 110v to 80v easier than adding a new power supply or would it be better to just get another power supply.
