Need Help! Look ahead blocks in KMOTIONCNC
Results 1 to 2 of 2
Thread: Look ahead blocks in KMOTIONCNC
    Member amitkumar171's Avatar
    Aug 2017
    India
    Default Look ahead blocks in KMOTIONCNC
    Hi tom,
    I am using dynomotion kflop board and kmotion cnc software. I want to know about look ahead parameter in kmotioncnc.
    As i have seen in many cnc machines look ahead parameter is in blocks e.g. 20 blocks. But in kmotion it is not clear that how many blocks kmotion cnc can read ahead . Or i want to know the look ahead blocks in kmotion cnc. ?
    I have seen the parameter in trajectory planner that look ahead in seconds , can you give that look ahead seconds to blocks conversion?
    Waiting for your kind reply.
    Regards
    Amit Kumar
    Member TomKerekes's Avatar
    May 2006
    Default Re: Look ahead blocks in KMOTIONCNC
    Hi Amit,
    The Interpreter/Trajectory Planner works ahead as many GCode Blocks as necessary until the planned motion is that amount of time ahead of the current machine position. This can potentially be hundreds of blocks of GCode. It depends on the GCode.
    Regards
    TK http://dynomotion.com
