HUANGYANG VFD HY01-D523B only Power led in display
Results 1 to 5 of 5
Thread: HUANGYANG VFD HY01-D523B only Power led in display
    Jan 2009
    Sweden
    Default HUANGYANG VFD HY01-D523B only Power led in display
    Hi ,
    Was just cutting out some wingparts for my Klemm 25L.
    Had to change material for the next cut.
    Suddenly my HUANGYANG VFD HY01-D523B won´t start up the spindle.
    Really strange since it has been working for some years now and no changes have been made as fx. wirering ect.ect.
    Spindle is a RattMotor 0.8 KW 220 Volt (GDZ-65f-800)
    VFD is HUANGYANG HY01-D523B
    The power led in display lights up, fan is starting and that´s about it.
    I´ve disabled the whole VFD to check:
    - capacitors - OK
    - Cable to the key pad (even from main board)- OK
    I really don´t know what else to check
    Is there anybody out there that can give me a clue or maybe have hade same issue and have a solution???
    Keep my fingers crossed that some one can reply :-)
    Thanks in advance
    Kent from Sweden
    Attached Thumbnails Attached Thumbnails HUANGYANG VFD HY01-D523B only Power led in display-huanyang-hy-01d-523b-vfd-jpg
    Jan 2005
    Default Re: HUANGYANG VFD HY01-D523B only Power led in display
    Quote Originally Posted by strobel View Post
    Hi ,
    - capacitors - OK
    Thanks in advance
    Kent from Sweden
    Have you just had it plugged in, or is it wired into the control, how have you been turning the main Power On / Off do you have a Ground / Earth connected
    Mactec54
    Member handlewanker's Avatar
    Sep 2006
    Try the VFD on another motor like a 3 phase one to see if it is the spindle and not the VFD.
    Ian.
    Jan 2009
    Sweden
    Hi again :-)
    Thank you all for your help!
    But it seems that I've managed to solve the issue (for now :-) )
    When I made my final check of the circuitboards I notised a cold joint on one of the boards.
    I resoldered that joint but without the result I wanted :-).
    So I resoldered ALL soldering point on the boards and - voilà! The VFD works again :-)
    The only negative thing is that I already orderd a new VFD :-(, well at least I will have spareparts if needed :-)
    Take care out there and stay healthy!!!
    Best regards to you all
    Kent
    Jan 2005
    Hi again :-)
    Kent
    Good you where able to fix it, most that have not burnt up the boards can be fixed
    I have done the same on a few of these that had not been burnt up, it can sometimes be the smallest connection that is not soldered well
    Mactec54
